Old 10-23-2010, 05:47 AM   #38 (permalink)
winkosmosis
Why would you run 65psi? Why would you even run sidewall max of 55psi? Now you see why it's foolish--- tires aren't cheap. Either you wear them unevenly with the high pressure or you damage them, and it ends up costing way more than you saved in gas.
