Old 10-23-2010, 08:23 AM   #43 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by SlideWRX View Post
On wings (planes or race cars), side plates effectively extend the wingspan
On aircraft, they are used to eliminate spanwise flow which reduces wing efficiency.
Basically, they keep the air where the designer/engineer wants it - in this case on the most aerodynamically efficient path on the vehicle.
Check out the Ford Bonneville car : it also has strakes on the roof and in front of the extended tailplate on the trunk, while the rear window sits slightly deeper, also creating a fence on the sides.
I wonder how much benefit one can get from a stepped down boat tail versus a regular boat tail. Better visibility out the rear window, methinks.
If the angle of the rear window isn't too large and abrupt, just boat-tailing the trunk area will most likely do the trick.
