Old 10-22-2010, 04:30 PM   #41 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
heh
not really, unless its corroborating with my theory of using the wingtail for downforce
~Mike
Old 10-22-2010, 10:40 PM   #42 (permalink)
Moostange - '07 Ford Mustang GT
Last 3: 21.8 mpg (US)
Originally Posted by AeroModder View Post
The Bonneville flat spoilers also have vertical plates on the sides.
I'll bet that helps interrupt vortex creation. On wings (planes or race cars), side plates effectively extend the wingspan, but I think they are also used to minimize vortex's. In this case, they probably also help the air flowing around the side pull in and re-attach, kinda like the air flowing over the roof going down to the trunk.
I wonder how much benefit one can get from a stepped down boat tail versus a regular boat tail. Better visibility out the rear window, methinks.
Tom
Old 10-23-2010, 08:23 AM   #43 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
On aircraft, they are used to eliminate spanwise flow which reduces wing efficiency.
Basically, they keep the air where the designer/engineer wants it - in this case on the most aerodynamically efficient path on the vehicle.
Check out the Ford Bonneville car : it also has strakes on the roof and in front of the extended tailplate on the trunk, while the rear window sits slightly deeper, also creating a fence on the sides.
If the angle of the rear window isn't too large and abrupt, just boat-tailing the trunk area will most likely do the trick.
Old 12-26-2010, 10:50 PM   #44 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
After seeing what Piwoslaw, Wyatt, Darin and others have done, I am wondering if I can create something similar for my Dodge RAM QC. Since I swapped the tonneau cover for a topper, I have noticed FE has dropped. I figure a kammback or boattail (boy would THAT be long....) would help drop the drag. Could I take the same basic picture here and apply it to my truck, or do I need to go to that extreme?
Sorry about the hi-jack. Dave
Originally Posted by cfg83 View Post
3dplane -
*IF* my center-of-camber selection is correct, then I would make the claim that the angle is too steep and the airflow is not staying attached :
I agree with Weather Spotter that a longer kamm-back would be better, but I also think that if you get the angles right, it should still be a net benefit. I think that aerohead had a table of "diminishing returns" of a boat-tail. Obviously a full boat-tail would be best, but pragmatic concerns make it necessary for ecomodders to figure out how far they want to go.
But I'll let the real aero-experts chime in.
CarloSW2
Old 12-27-2010, 01:16 AM   #45 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
ECONORAM -
I don't have the answer to your question, but the slope might look something like this (if I have the correct image) :
CarloSW2
American Solar Energy Society
Old 12-27-2010, 09:51 AM   #46 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
ECONORAM -
CarloSW2
That looks about right to me. I have seen people just go from cab roof to top of tail gate with good results but following the template is better.
Old 12-27-2010, 11:14 AM   #47 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Talking
ECONORAM -
CarloSW2
You could do this...
http://ecomodder.com/forum/showthrea...dea-15137.html
Article: ecomodding a vanilla Renault production sedan... efficiency up 19% MetroMPG EcoModding Central 40 11-02-2012 05:15 PM
Help me design my partial Kammback Weather Spotter Aerodynamics 67 09-12-2010 06:47 PM
Kamming a sedan GrandPrix Phantom Aerodynamics 4 08-15-2010 06:37 PM
News: GM's chairman - "small cars don't work in this country" MetroMPG General Efficiency Discussion 32 11-19-2008 06:50 PM
1995+ Metro sedan coefficient of drag: .32 MetroMPG Aerodynamics 1 07-16-2008 10:02 AM
