Originally Posted by EdKiefer
right into the compressor wheel
12 pounds in a manta - not bad
what kind of jet were you using. did your compressor wheel get pitted?
it is said they move at supersonic speeds and any object other than air
can cause damage to the vanes.
were you using tap water? distilled water should eliminate mineral deposits.
in FE engines you might find better sucess using water vapor instead of spray.
