Originally Posted by UFO
Yes there are tradeoffs, but I am not convinced NOx is a serious problem. Acid rain is not an issue in the front range of Colorado, smog was much worse than it is now. My understanding of acid rain is it's caused mostly the sulfur from coal plants.
So if the NOx you produce doesn't effect you locally, then it's not a problem?
What matters is
where you're going, not
how fast.
