...two clear plastic tubes = slide-on "guides" to protect the gaskets as you slide them over the "injector pintle" when pushing each one into position?
...also, if those valve-stem "locks" are steel, use a small magnet to 'catch & hold' them as you compress the spring, otherwise them might snap out and disappear on you.
