start with the top, that got me .78 MPG and worked fine all summer.
The lower one I would start blocking as it gets cold. If you have a good temp gauge (that you can see when the fan comes on and off) then match the grill block to keep the fan off 95% of the time. If not just go till the lower grill is 60% blocked (dead of winter).
