Thread: Grillblock
Old 10-28-2010, 11:18 PM   #11 (permalink)
NeilBlanchard
Hi,
Originally Posted by Angelus359 View Post
I was looking at it... and if I blocked the top, and I blocked inbetween the bottom grill and the radiator, underneath, I probably could get away with even smaller, because its forcing all the air through the radiator, and not around to anywhere else. Almost like ducting.
Yes, this will help. My xA is down to a 15" x 4" opening, and blocking the chin opening will help if the front opening is small enough. If you leave too big an opening, then closing the chin area will "parachute" and add some drag.
http://ecomodder.com/forum/showthrea...tml#post132996
I need to take a picture of the current grill block -- I'm using aluminum roll flashing now.
