Old 10-29-2010, 12:04 PM   #3934 (permalink)
jyanof
Joe
Originally Posted by Dwffy View Post
I open the 12v bosch relay which I used to switch the heater on and off because it says it can handle 30 amps. The contacts were welded together so I now conclude that there must be a way that I can turn my heater on and off without burning up relays, but I am at my wits end.
as Jack said, you'll have to find a relay rated for your voltage. But, just to reiterate, make sure you find something that is DC rated. A 120V AC rated relay will not be able to break 120 VDC (I think it's only like 38VDC, some of the AC relays will also have a lower DC rating).
I had purchased a 150VDC 20A relay from one of the EV suppliers... shoot, i can't figure out where I got it, but it was about $20.
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
