Old 10-29-2010, 01:36 PM   #236 (permalink)
3-Wheeler
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by Weather Spotter View Post
....10-15% was in the range of what I was expecting, someone one my idea thread thought I would get 20-30% which just seamed too high.
I think what that person might have meant was, your total gain from the tail really will be 20 to 30%, but because rolling drag and air drag are equally split regarding affect on the vehicle, the aero benefit is cut in half, so you end up with an effective gain of 10 to 15% from the aero side of things.
...Any design guidance? I have to make a window in mine and will likely go the solid over built way. I put up some drawings of a rough shape, do they look right?
Well one big piece of advise I can give is make sure your overall body shape matches the AeroHead template. I worked over these numbers with Phil quite a bit. Look on the following page for more info...
http://ecomodder.com/forum/showthrea...t-13533-8.html
That thread talks about the streamlining template quite a bit, so take a close look before making your final design.
Jim.
The Following User Says Thank You to 3-Wheeler For This Useful Post:
Weather Spotter (10-29-2010)
