Buy a 220v ceramic heater and take it appart, you will find a ceramic chunk in there with heating wire wrapped around it, messure how long that wire is, divide it by 220 and multiply it by 96 and that will tell you how long of chunks of wire you need to cut, the ceramic acts as a high temp heat sink to help spread the heat so you can pull more heat out of a smaller area.
