Old 11-01-2010, 03:50 PM   #45 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
This is similar to what I have in mind for my hatchback. I have welded up the support that plugs into the hitch but that is as far as I have gotten. I am going to leave the top lower than the top of the hatch glass to leave a space to see out of. It's not quite as clean aerodynamically but I should get some of the benefit, especially if the sides are at the correct angles and the top intersects with the template. The top could be hinged to allow normal function of the hatch.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
