Old 11-03-2010, 10:37 AM   #259 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by fusion210 View Post
Your tail looks most excellent! Any more pics? I noticed the pic in your av and couldn't help but wonder what other ones you have of it out in the open.
Maybe the tail is not finished enough for unveiling? But you must have protected it with something so the winter rain and snow doesn't melt the spackeling, right? Do tell.
Also, I am hoping to see some more photos of your LED tail light array in action. It looks like you used a slew of bulbs instead of just replacing the factory ones like I did. Yours should be much brighter than stock. Amazing craftsmanship, by the way.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
