Old 11-05-2010, 01:41 PM   #5 (permalink)
EdKiefer
Thats no were near what you need. It is easy to draw 25 amps with just a few things on . Just the radiator fans are a good load .
I am going to guess with nothing on the lowest you draw would be around 7-12amps but that is no way realistic use .
If cooling fans go on and its nighttime your way above that . you probably need something like 350-450W to cover most running conditions . Thats omitting any kind of high end sound system too .
