Old 11-05-2010, 07:24 PM   #2 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Hi donee -
I split this topic from where it started, in: http://ecomodder.com/forum/showthrea...tml#post202701
I assume since the subject of that thread was flow on the rear window, you're thinking the 2010 Prius has problems in the same area?
Easiest way to confirm this is tuft testing - and it truly is easy, because you can see the results in your rear view mirror!
I predict there is no flow separation on the car's back window (the upper, main one).
I'm not sure what you're referring to in terms of coastdown comparisons. Are you saying a 3rd gen Prius doesn't coast as far as a 2nd gen?
PS - I didn't read about losing your Prius - sorry to hear that.
