Old 11-05-2010, 08:03 PM   #7 (permalink)
apowers
apowers's Avatar
On the potentiometer one wire should be connected to the center terminal and one to one of the other terminals. Depending on what direction you want the potetiometer to turn. I noticed that the thermister is mounted on the board and not inbedded in the heat spreader. That should not keep it from working but might not do much good there.
Alvin
