Old 11-06-2010, 06:57 PM   #207 (permalink)
GeneralAnarchy
Originally Posted by ericbecky View Post
The BMS will come in a separate shipment. Could be a few weeks.
I just got the new BMS. It has two boxes, the smaller box with digital display has an SD card slot. An SD card reader is included too. They appear to link together with the USB cable. There are two connectors on each of the RFE batteries which appear to plug in to the larger box. Each battery, aside from it's main power connection, has a mini connector and a smaller one about half the number of pins. These smaller connectors appear to plug into clearly label places on the BMS unit, but there are no included instructions. When you say they must be in some sequence, what do you mean?
