Old 11-07-2010, 10:55 AM   #7 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Craig, I like the flush headlight mod, it cleans up the front end a little. I read through your swap on TDIclub. Awesome build! As we go into winter I think you will find you can really close up a lot of the grill opening on a diesel and it will be happier. The block heater helps too. Does your engine have the cast magnesium oil pan? You may want to consider fabbing up a belly pan. It helps aerodynamics and may save your engine (and helps keep it warmer in winter and protect it from grime) A coroplast belly pan from the cat back really helped my highway mileage.
Welcome to Ecomodder, it's nice to have someone with your build skills on this site.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
