Old 11-08-2010, 12:25 PM   #3968 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by MPaulHolmes View Post
1000amp current sensor results!
OK part number CENTRON CSA-1V
Now, the centron was soldered to a single sided pcb. For a measurement range of 0-1016amp, the bottom of the pcb needs to be 0.75" away (actually 0.754") from the bus bar. That's 12 bare fiberglass boards (pcbs without the copper). Higher temperatures make the current read slightly less than it actually is.
I also ordered a part (that's on a 25 week back order) that should be able to be much closer to the bus bar.
What ever happened to the testing on the 1000amp current sensor
-Mark
