Old 11-07-2010, 09:17 AM   #3961 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Current sensor
Paul,
what is projected for the SR controller current sensor?
Are we still in the path of the LEM HASS 300-s?
if so, We will be able to upgrade to higer current handling (600) with out much softw. modification?
Thank you
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 11-07-2010, 09:22 AM   #3962 (permalink)
EVVette - '71 Chevy Corvette Coupe
Originally Posted by mrbigh View Post
Paul,
Are still in the path of the LEM HASS 300-s?
Thank you
You wont have to worry about upgrading current sensors until you pass 900A. Thats as high as the LEM HASS Series can read.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 11-08-2010, 08:43 AM   #3963 (permalink)
ElectricZX2 - '98 Ford ZX2 Cool Coupe
90 day: 140.91 mpg (US)
I probably don't know enough to be posting about the LEM but if you need more than 900 amps could you just have two parallel conductors and only measure the current in one of them with the LEM? You would be measuring half the current but you could just adjust the software accordingly...
The Following User Says Thank You to ElectricZX2 For This Useful Post:
mpgmike (01-18-2022)
Old 11-08-2010, 08:53 AM   #3964 (permalink)
In theory the idea works fine, but you have to guarantee that the both conductors would be sharing current evenly. If they are not, you reading will be off.
-Adam
Old 11-08-2010, 09:16 AM   #3965 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Pwrx vla500
Adam,
What's the tally on the VLA500-01 subscribers?
Old 11-08-2010, 09:19 AM   #3966 (permalink)
Adam,
Umm...5 or 6. I'm on my phone so I will check when I get back to my computer. It's only 3 people. One is me the second is you. Lol
-Adam
Old 11-08-2010, 09:40 AM   #3967 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Talking Parts questions
Originally Posted by jackbauer View Post
the new build continues. Hope to do final testing and assembly this evening. Note the two resistors and schottky diode used on the igbt drive and the shorted gate to emitter pins on the high side for use as freewheel diode.
jackbauer
I have some 2uf x1500vdc with tabs for direct mounting to the IGBT terminals but this are to physicaly large for my application.
Witch value you used for the poly film cap in the capacitor rails and the IGBTs in your last controller build?
I have to place a parts order for the LEM HASS and would like to include the capacitors also.
Horacio
Old 11-08-2010, 11:25 AM   #3968 (permalink)
ReVolt Enthusiast
Originally Posted by MPaulHolmes View Post
1000amp current sensor results!
OK part number CENTRON CSA-1V
Now, the centron was soldered to a single sided pcb. For a measurement range of 0-1016amp, the bottom of the pcb needs to be 0.75" away (actually 0.754") from the bus bar. That's 12 bare fiberglass boards (pcbs without the copper). Higher temperatures make the current read slightly less than it actually is.
I also ordered a part (that's on a 25 week back order) that should be able to be much closer to the bus bar.
What ever happened to the testing on the 1000amp current sensor
-Mark
Old 11-08-2010, 02:26 PM   #3969 (permalink)
jackbauer's Avatar
The caps are 1uf 250v poly. not ideal but its what my supplier had in stock. Also count me in for the drivers.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 11-14-2010, 11:32 PM   #3970 (permalink)
Sorry for the late response on here just haven't had time to post but my situation hasn't changed so I just went back to the arduino pwm that I had only problem now is that revolt board fried almost all my fla batteries within an instant I think this board needs some serious disclaimers put into the wiki because what I originally thought was if the yellow LED didn't blink then everything was ok but apparently that is not the case if I would have known that if even one component like the NAND or comparator were bad and would cause my whole power section to blow up I probably would have not bought this board and the components and would have continued to develop my own board. I still do not buy that the issue was frequency because I have run these at 8k with a 555 circuit no prob. What if one of my Chips were bad from the factory and it ended up blowing up the mosfet section I purchased made for the revolt board would I get a refund for that? NO I wouldn't. There should be a big disclaimer addressing this issue and testing procedures before installing some of these components on the board.
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
