Old 11-08-2010, 06:55 PM   #277 (permalink)
donee
- - '10 Toyota Prius III w/Navi
Hi Varn,
The issue (for the benefit of others) is how fast you can mix, and apply it. Its open time is short, and defenitaly variable based on the shape of the mixed container, and the final shape of the part. The practicality of this, is that really good parts can only be made so big by a single person. If the epoxy is not at the same state of cure in layers, its not going to make a good part. That is, if you have one end of an object half cured, and then apply freshly mixed epoxy on the other end there is going to be a
"knit" line that is prone to failure.
Allot of the problem can be eliminated with the vacuum bagging technique called "vacuum infusion" The epoxy is pulled into the matrix uniformly and quickly by this method. Two people can impregnate structures up to 50 foot long in a matter of hours, with a superior build quality. There was a video on the internet of this done by a Dutch boat builder. It was quite remarkable how straightforward and undramatic the impregnation was, in comparison to traditional techniques such as hand-lay-up.
