Old 11-11-2010, 09:20 PM   #17 (permalink)
Zerohour
Zerohour's Avatar
Pooparu - '01 Subaru Outback Limited
90 day: 28.12 mpg (US)
Cop Car - '94 Chevy Caprice Interceptor 9C1
Last 3: 18.48 mpg (US)
Mini - '11 Mini Cooper
90 day: 37.63 mpg (US)
Gramps - '95 Subaru Legacy Postal
90 day: 23.18 mpg (US)
Can you set the alarm to instant MPG? Or the "load" equivalent? That's what I would want for driving with load - at cruise on the open road.
Only driven 30 miles with it, still need to top off the tank and zero the gauge. then get a proper calibration after I use fuel out of the tank.
I might start tinkering with the alarms at one point, but I've been still working on setting up the 18 custom display gauges.
I'm not 100% sure what can be set to alarm. Pretty sure most standard gauges can be.
All that be said, I don't think you'll be able to use the UG with an non-OBDII vehicle. (not sure if it gets information from the OBDI port).
Your best bet would be vacuum gauge, or some type of variable resistor wired to the throttle.
