Been working on the car, and have took apart the front, and cut out all the metal that wasn't strictly necessary. Removed 20lbs of wiring, 30lbs of front support, and 30lbs of front body. Fenders are only 20lbs, so not sure I will save much weight using fiberglass. I will be getting a fiberglass hood,
and will probably fabricate a front body/bumper/grill that will be a bit different than the stock MG for better aerodynamics.
