Old 11-14-2010, 09:31 PM   #2 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
Congrats on the purchase!
Originally Posted by dday View Post
was told by the previous owner that it would go about 15 miles on a charge
Have you asked them about this? Might be worth a phone call.
Shouldn't I be getting more miles out of a charge than that?
Not if the batteries are tired!
FYI, the most important instrument in the ForkenSwift is the LED battery gauge. Being able to monitor each battery at a glance in real time (under varying load conditions) is invaluable for protecting the weakest ones from damage by drawing the voltage too low under load.
... And for learning what kind of range they'll deliver (before voltage sags too much to continue "normal" use).
You could do the same thing with a bunch of multimeters.
dday (11-15-2010)
