Old 11-16-2010, 10:18 AM   #10 (permalink)
apowers
apowers's Avatar
If a mosfet is is dead with a short it will allow power to go to the motor when the contactor is turned on. Even without pedal. All of the mosfets may not be bad. If they are still hooked up they all will show a short. If you un-solder a source or drain one at a time and recheck you can find the bad one. There can be more than one.
