Originally Posted by alohaspirit
Got the update. Tires at max pressure 44psi. Thought about moving the LP lower but we'll see if that actually happens. (I know you notch the holder but I dont have a dremel) And I wont be using a KN filter but the air filter IS dirty so Ill probably be replacing it along with the oil. Stupid expensive 0w-20!
And Ive tried different ways of going up the hill. (Speed/RPM wise)
Sadly though the speed is only 25mph but most people go 40-ish.
(its not worth the $100+ ticket however)
Cool youre running the marathon. Not the first time I take it?
I lowered the LP holder by rotating 180 degrees, then notching using a pair of avaition tin snips. Also had to use longer bolts.
I have run 6 marathons so far this year.
If your top speed is 25 I can tell you that the HCH does not get great FE in that range. Seems the sweat spot is around 60 - 65 mph for me.
The IMA has about 8 modes that it goes through from stopped to cruising speed. So it may be your in a mode that is not as FE.
Really looking forward to the warm temps on Kona since I shoveled 5" of snow today!
Cheers!
