Old 11-21-2010, 06:07 PM   #11 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
Originally Posted by Piwoslaw View Post
Nice
Any way to reduce weight? That's probably what would help you the most on the Evil Hill. Keep trying with technique, I'm sure you'll find a sweet spot.
Ive been working on that. (Doing a lot of cardio lately )
Past Present Future?
Old 11-21-2010, 11:32 PM   #12 (permalink)
Polymorphic Modder
SoobieOut's Avatar
2006 DaCivic Hybrid - '06 Honda Civic Hybrid
90 day: 45.16 mpg (US)
Originally Posted by alohaspirit View Post
Got the update. Tires at max pressure 44psi. Thought about moving the LP lower but we'll see if that actually happens. (I know you notch the holder but I dont have a dremel) And I wont be using a KN filter but the air filter IS dirty so Ill probably be replacing it along with the oil. Stupid expensive 0w-20!
And Ive tried different ways of going up the hill. (Speed/RPM wise)
Sadly though the speed is only 25mph but most people go 40-ish.
(its not worth the $100+ ticket however)
Cool youre running the marathon. Not the first time I take it?
I lowered the LP holder by rotating 180 degrees, then notching using a pair of avaition tin snips. Also had to use longer bolts.
I have run 6 marathons so far this year.
If your top speed is 25 I can tell you that the HCH does not get great FE in that range. Seems the sweat spot is around 60 - 65 mph for me.
The IMA has about 8 modes that it goes through from stopped to cruising speed. So it may be your in a mode that is not as FE.
Really looking forward to the warm temps on Kona since I shoveled 5" of snow today!
Cheers!
Old 11-22-2010, 01:09 AM   #13 (permalink)
Post your car and gas logs Dave!
CleanMPG, - Garage An authoritative source on fuel economy and hypermiling
-soD
Old 11-24-2010, 04:51 PM   #14 (permalink)
Grasshopper
I knew about the LP flip but not the longer bolts.
Have fun in Kona. Its honestly too warm for me there.
Nice log Dave
Got 39.8mpg on my last fill!
Ill be doing an air filter change soon and then logging another tank to see the difference.
Then Ill do the oil change with the same process.
Old 12-04-2010, 03:18 AM   #15 (permalink)
Grasshopper
39mpg over 3 tanks
new air filter is in (old one was really clogged)
will report the difference
Old 12-04-2010, 10:42 AM   #16 (permalink)
Polymorphic Modder
SoobieOut's Avatar
I changed to a K&N about a year ago, seems to help.
I have noticed that in the past month I seem to have more power, I wonder if there is a learning curve from the latest IMA reprogramming.
Also I just bought both shop manuals for the 2006 civic hybrid on Ebay. If you need me to look something up or scan a page, let me know.
Leaving for Hawaii on Tuesday!!! WooHoo can't wait to feel the warm sand between my toes!!
Old 12-05-2010, 08:48 AM   #17 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Doesn't coast well? Check brakes, make sure if the tires were replaced that it's got LRR's on, and watch your pressure!
Does it have all of the underbody panels its supposed to?
Old 12-05-2010, 12:44 PM   #18 (permalink)
Grasshopper
check check
tires are at max but they are a little old
Old 12-12-2010, 04:59 PM   #19 (permalink)
Grasshopper
Installed new air filter. Old one was pretty dusty.
New Record: 40.35mpg!
Next on list: Oil Change
Old 12-13-2010, 10:57 AM   #20 (permalink)
90 day: 57.73 mpg (US)
Tires: old & worn likely have lower rolling resistance. But less grip. And you have lots of rain, so...
Congrats on the new record!
Esajuppeli (06-28-2017)
Canadian 8th Gen. Civic Gears superchow EcoModding Central 1 06-20-2013 12:52 PM
Looking at an '04 Civic Hybrid Formula413 General Efficiency Discussion 14 11-20-2009 08:12 PM
civic hybrid wheels jjcivic EcoModding Central 3 07-21-2009 05:45 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 11:45 AM
Milwaukee Hybrid Group Meet 3-28-09 Daox Events & Meet-ups 1 03-28-2009 10:04 PM
