Old 11-23-2010, 11:40 AM   #7 (permalink)
EdKiefer
Originally Posted by johnnymac View Post
I am guessing it is 195 because it mostly hovers right around that temp. So a grille block is OK up to 205-210?
I would say you want to block the grill to the point it doesn't raise temps much under similar conditions .
If you avg 197-200 then block grill no more than 200-205, you don't want the blocked grill to trigger fans because you blocked to much area .
