Old 11-19-2010, 05:30 PM   #1 (permalink)
johnnymac's Avatar
Goldie - '99 Ford Escort el cheapo
What is too hot?
Greetings,
I have been a member for awhile now and I am impressed with all of the innovative people and all of the great info. I just purchased a 1999 Escort 2.0 5 speed. My odometer reads 208K, and it runs and drives great. I am getting about 39 MPG with it. I had an Echo, and other Escorts before that.
I am going to install a grille block and want to know what is a good safe temp to run at. It has a scangauge II and it shows the car has been operating at about 197 degrees most of the time. + or - a few degrees. Usually 197.
I have read escorts can get hot, overheated, and drop a valve seat. I saw a old escort in the bone yard with a hole through the upper front of #4 cylinder and now I know why.
I'm running my tires at 42 psi, I have Goodyear Vivas in the front (44max)and Primewells in the back (40 max), all in very good condition so I'll run what I have for now. I want to make skirts, add a grille block and a warm air intake. She is a beaut but the scangauge does not come on when I first start up.
Thanks to all,
John
2006 Pontiac Vibe 36 MPG 5 speed
1999 Ford Escort Base Model 2.0 5 speed
Scangage II
WAI
FULL disc wheel covers
Sears Guardsman plus tires 44 PSI
Best tank 42 MPG 244K
Old 11-19-2010, 06:23 PM   #2 (permalink)
Originally Posted by johnnymac View Post
Greetings,
Thanks to all,
John
well your fine now, you probably have 195F thermostat .
Not sure on your vehicle but many older fords electric fans come on around 215-220 (which is a little high IMO ).
If it was my car while moving I wouldn't like it over 205-210 , then stopped if should come on when fans trigger it .
just make sure everything is in good shape. full coolant, radiator clean (no clogged cores) and rest of engine good shape .
Those other cars probably had combination of few things wrong or running real low on coolant .
Old 11-19-2010, 06:25 PM   #3 (permalink)
...beats walking...
...what's the thermostat temperature (°F), you typically shouldn't get more than 10% higher (or lower) during normal operation.
Old 11-22-2010, 05:13 PM   #4 (permalink)
johnnymac's Avatar
I am guessing it is 195 because it mostly hovers right around that temp. So a grille block is OK up to 205-210?
Scangage II
WAI
Old 11-22-2010, 11:04 PM   #5 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
Yup. Most modern cars are a 195* t-stat, so yours likely is as well.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 11-23-2010, 12:07 AM   #6 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I wouldn't worry about 197, I would worry about 205+ though.
Old 11-23-2010, 10:40 AM   #7 (permalink)
I would say you want to block the grill to the point it doesn't raise temps much under similar conditions .
If you avg 197-200 then block grill no more than 200-205, you don't want the blocked grill to trigger fans because you blocked to much area .
Old 11-23-2010, 05:54 PM   #8 (permalink)
As long as your fans don't trigger until 210* or later, 210* is fine for continuous operation of a modern engine. They don't mind running warm at all.
Coolant Temp: How Hot is Too Hot? RH77 EcoModding Central 7 02-23-2009 04:33 PM
Subaru Outback Hot Air Intake Results brucey EcoModding Central 22 12-10-2008 07:41 PM
Hot water from oil in the summer time. Xringer Saving@Home 11 09-06-2008 10:02 PM
How hot is too hot for a Metro/Swift Wayneburg General Efficiency Discussion 3 05-07-2008 09:12 PM
