Old 11-24-2010, 08:57 AM   #29 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by Clev View Post
An 80cc or 150cc 4-stroke driving an Etek (especially if you can go with, say, a 72V drive system so you don't have to boost/buck your Etek to match) would be a lot more efficient, if not as clean. A biofueled diesel of equivalent power would probably be even more efficient, with noise and vibration being the inherent problems.
Alohaspirit,
Sorry about being off topic ......
Clev,
You basically described an SAE Formula Hybrid - Formula Hybrid
Most of the SAE Formula Hybrids built use a 250cc 4-stroke driving an Etek for charging. Both Series and Parallel Hybrid systems are used. Some of the teams are using SuperCaps in series with the battery packs to balance the discharge load under acceleration, and to capture regenerative braking energy.
-Mark
