Old 11-25-2010, 04:21 PM   #53 (permalink)
nimblemotors
EcoModding Jack
nimblemotors's Avatar
This is polyurethane two-part mixed and pour foam.
TAP X-30 Polyurethane Foam: TAP Plastics
I'm not aware of a shrinkage problem with the stuff.
Is that foam something you mixed & poured? Doesn't look like you sprayed it from a can.
Some people here have had bad luck with the foam, since it seems to cure unevenly, or shrink with age. I'm guessing you've done this before.
The Following User Says Thank You to nimblemotors For This Useful Post:
MetroMPG (11-25-2010)
