Old 11-26-2010, 04:05 PM   #18 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Originally Posted by z3pilot99 View Post
We/I have a cable speedometer. It is a 1990 HF. So, do I still have a VSS?
Might help: http://ecomodder.com/forum/showthrea...html#post77756
I think we also need to know the flow rate on the injectors.
Not really. You can put in a guesstimate and calibrated it from tank fill-ups after. Have a search around the MPGuino subforum.
With my ELD inop if I drive when it is dark and my lights are on can the drag from the altenator be causing a decrease in fuel mileage? That is the only real variable now.
Yes. Curious to see your results when you get that sorted out.
Weather - wind, precip & temperature all have a fairly big effect on fuel economy as well.
