Old 11-28-2010, 04:37 PM   #28 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Originally Posted by 99kleansi View Post
Funny thing is with the amount of programing that goes into my car the AC switch changes fuel and ignition tables to run on cheaper fuel and increase the milage while reducing power.
You should start a thread on how you were able to improve the efficiency of the already economical Civic.
You already mentioned you had a 4" exhaust on your Civic, which I'm sure went along with a similarly up-sized intake and different cams. How did you minimize the negative FE impact of those modifications?
