Old 11-30-2010, 05:45 PM   #17 (permalink)
abently
turquoise - '97 Toyota Starlet
90 day: 41.46 mpg (US)
Originally Posted by ShadeTreeMech View Post
+1
Considering you're fortunate enough to have a manual, why not use EOC? Restarts would be easy as pie if you use bump starting, and adding a manual kill switch instead of having to use the key would make it even easier.
What tire pressure do you run? Many folks here run at 50 psi (3.4 bar)
I'm at 40 or 42 psi, doing 44 or 46psi in a couple days time, with my next fill.
New clutch is being organised so once that is on and a few aero tweaks done, I'll then see how far EOC gets me.
