Old 12-02-2010, 01:16 PM   #219 (permalink)
GeneralAnarchy
I don't know for sure if the case sits too low... But if I unlock and open the floor panel the front edge pulls away from the other panel and the tabs do not line up. It's seems too low. I have to lift front edge of the panel a bit or jiggle the whole thing and shove it forward before closing and relocking the panel. Even then it still is not totally flush like it was. There is a small "step" there. I'll take a closer look on the weekend, I just thought it might be a common problem.
I drove it to Madison and back a couple days ago, I should have asked you to take a look. Seems like my headlights aim higher now! The weight is significant. Enginer should sell suspension mods. Thanks for the idea with the velcro, exactly an idea I needed and sounds like a perfect spot.
