Originally Posted by BHarvey
Should I buy a scan gauge for monitoring temps with using a grill block?
Yes. Modern temperature gauges are glorified "idiot lights". That is, they generally go to "normal" and just stay there. The Scanguage shows true temperature and a whole lot more. It helps you to figure out just how much of the grill you can block for outside temperatures and long hills. Grill block helps with aero and quicker warmup, both good things.
