Old 04-20-2008, 02:04 PM   #1 (permalink)
RH77
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
Exclamation Need Timing Help
I followed the standard procedure for Honda timing advancement:
Warmed up until the fan kicks-on
Shut down
Jumped the Timing-ECU Isolation (paper-clip trick)
Started Up
Rotated the Distrib counter-clockwise until until I could hear knock
But I didn't hear any knock. All 3 bolt points were in their furthest position. I even tried full clockwise in case my info was incorrect. I placed it in full advance, shut down, removed the clip/jumper, and went for a drive.
IAT = 110F, Coolant = 200F
Full throttle to 7250 RPM -- no knock. I've heard it before in similar instances when the IATs were out of control.
The car does not have a knock sensor and IGN on the SG is acting normally.
Tried a low-RPM, hi-load situation. No knock. A/C on. No knock. Tried a variety of high load situations.
Do I just leave it and expect a bump in FE?
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
