Old 04-20-2008, 03:26 PM   #21 (permalink)
Funny
Funny's Avatar
Eco-Fit - '13 Honda Fit Base
90 day: 37.06 mpg (US)
Originally Posted by PaleMelanesian View Post
Accuracy - I've got a year and over 10,000 miles on mine. I've recorded the actual gallons and back-calculated the un-adjusted gallons for each fill. Once I locked in my offset, it's been +- 1% or so for the whole year.
I've had my original SG since mid 2006, about 50,000 miles ago, when I started reading Darin's website, www.metroMPG.com. These SGs are able to be adjusted to match the readings at the pump, it usually takes a few tanks to get it to be within the 1-2% range of accuracy. But, like Ron Popeil says, "Set it and Forget it!" Once you have the percentage fuel consumption changed to match the pump, your Instantaneous and Trip MPGs will be right on the money.
The percent offset settings for the fuel are in the settings>fill up> section of the scan gauge, if my memory serves me correctly. Check out this thread and that should help.
American by right
Ecomodder by choice
Hypermiler by necessity
