Old 12-03-2010, 08:52 PM   #8 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
When the seasons change I try to check them more often. The change in air temp causes changes in tire pressure - especially important in fall when the temp drops. 20-30 degrees of temperature drop plus a very slow leak can mean pressure much lower than what you wanted.
I try to get a look at them every day, and I admit to putting the gauge on them only every 2-4 weeks.
I found one tire low (20 psi) on my old Volvo this week; I tracked it down to a cracked valve stem. First time I've ever seen that happen. Bought those stems at a big box parts store - should have just let the installer put in regular ones.
Coast long and prosper.
