Old 12-05-2010, 01:12 AM   #15 (permalink)
Allch Chcar
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Originally Posted by honestabe View Post
E85 is more like a race gas. I'd use it in my Supra if I were wanting to really make some power without having to spend $10-20/gallon. If you use E85, you will need to increase your fuel system's ability. To use E85 you need to increase your fuel flow rate by 20%, meaning you get much worse MPG than with regular gas.
Increasing the flow rate by %%% does not mean the MPG goes down %%%. Driving style mixed with the tune determine the final MPG. If you leaned out the tune at cruising RPM you could get better MPG but couldn't you do the same for RG Gasoline too?
Due to hanging out on Honda-tech where quite a few E85 tuning discussion goes on, I know the number is not flat across the board. One particular tuner, who's name I have forgotten, noticed that E85 on one particular engine only needed 10% or so more fuel in the low RPM vs closer to 50% for high RPM WOT. Setting it to +33%(IE) across the board ruined performance or so I recall from memory. The numbers are not exact, but you should get the idea, the amount of fuel needed depends on many variables and needs to be tuned accordingly. Each engine is different and E85 has several grades.
So please don't go throwing around numbers like that. eg saying E85 needs this much more fuel etc. The amoun of fuel is very dependent on the engine, weather, and % of Ethanol. Not to mention how the tuner decides to go, they might lean it out during cruise, put everything to stoich for a DD, or even enrichen the mixture to add more power. I've seen far too many throw numbers anywhere from 20% to 2x the fuel, all of it is bogus. Anyone who claims to know the number and to know it all for a fact is a fool. There could be a range but even that is guess work. The number people are often referring to is the difference between "pure Gasoline's" Stoichiometry and Ethanol's which is approx 42% more fuel for Ethanol over the old "pure Gasoline" w/o ethanol. But every engine is different and the number would almost never be 42%.
This is Ecomodder, more facts less feces.
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
Boreas (12-05-2010)
