Old 12-06-2010, 11:17 AM   #7 (permalink)
crawlerdan
Originally Posted by dennyt View Post
I'm sure it does, I have a '94 Loyale (the predecessor to the Legacy) and I found a VSS signal. The ECU uses it.
your loyal uses a cable for the speedo/odo as well as mine does
so where are you picking up a VSS? Thing i could think of is maybe somewhere in the ABS system, but i dont have abs, and neither do you.
i would like to see how you hooked up a mpguino if you have one though
