Old 12-05-2010, 11:41 PM   #1 (permalink)
Subaru legacy???
hello- im new here
i drive a 91 legacy wagon
i am always striving for as much mpgs as possible without been retarded or dangerous
heres what ive done to my 2.2 litre 4 cyl and 5spd AWD car
ive added a free flowing intake and exhaust
lifted the car 3.5 inches to allow fitment of drastically larger tires. at highway speeds the larger tires act as an overdrive, lowering my rpms at a given speed 9%. they are inflated to sidewall max
i went from a 195 70 14, to a 205 70 16
ive also installed a vacuum guage and monitor it
ive reduced weight significantly without sacraficing the utility of the car and the fact im a father of 2
if removed cross bars in the roof rack
as much as i would like to monitor using a scanguage, it is an obd1 car....i have one on my 4runner though
what else do the pros recomend i do with an obd1 station wagon with a lift kit? im looking to drive it cross country in the near future and want to save dough ....hehehe a turtle
Old 12-06-2010, 07:37 AM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
I think you're going to have a little trouble with that, but you could start with an mpguino, returning the car to stock ride height, adding a grille block and removing the roof rack, and getting some low rolling resistance tires.
Old 12-06-2010, 10:22 AM   #3 (permalink)
well- i noticed a significant increase in MPG with the larger tires, like i said, they act as a sort of overdrive. plus- i need the ground clearance- i live on a farm
what is a mpguino?
Old 12-06-2010, 10:34 AM   #4 (permalink)
ok- did some research and found it.
problem is- my car does not have a VSS, it is a cable and analog guage
Old 12-06-2010, 11:01 AM   #5 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Welcome to the forums!
Have you looked over this list of proven mods? It has nice user data to show MPG gains:
Car MPG Efficiency Modifications Main - EcoModder
A grill block is a good first place to start. With the car raised a belly pan is a must.
Old 12-06-2010, 11:05 AM   #6 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
I'm sure it does, I have a '94 Loyale (the predecessor to the Legacy) and I found a VSS signal. The ECU uses it.
Old 12-06-2010, 11:17 AM   #7 (permalink)
your loyal uses a cable for the speedo/odo as well as mine does
so where are you picking up a VSS? Thing i could think of is maybe somewhere in the ABS system, but i dont have abs, and neither do you.
i would like to see how you hooked up a mpguino if you have one though
Old 12-06-2010, 11:19 AM   #8 (permalink)
haha- your on USMB too. small world
Old 12-06-2010, 11:21 AM   #9 (permalink)
in tents
dennyt's Avatar
Subaru
I'd have to look at the wiring diagram again, but there's a vehicle speed signal coming from the transmission. I tapped into it at a connector under the dash.
I don't have my MPGuino up and running yet because my (single) fuel injector is the peak-and-hold type, and the 'guino is set up for the more modern type. But the MPGuino does read speed correctly.
Old 12-06-2010, 11:25 AM   #10 (permalink)
the mods i have on my legacy ive done to several other subarus. this is my 21st in my name, and 88th thats passed through for whatever reason
my 92 loyal with a 3 inch lift and larger tires consistantly yeilded 43mpg
my 86 gl with a carb and lift kit, low rolling resistance tires, saw 35 avarage
SUBARU AWD to two wheel drive gunrunner EcoModding Central 6 02-28-2012 11:26 PM
Subaru CVT vs 6-speed Manual bmwboarder General Efficiency Discussion 6 09-28-2010 01:07 PM
Subaru Justy Gear Swap? mtgeekman EcoModding Central 4 08-19-2009 11:33 PM
1987 subaru: hypermiler mode bgd73 Success Stories 0 07-24-2009 03:47 PM
Mpguino 98 subaru legacy Csht OpenGauge / MPGuino FE computer 0 11-16-2008 04:39 PM
