Great write ups! Have you finished or started work on the underbelly pan? To put my two cents into the problem covering your spare tire. You could cover the entire area, then cut out the part for the spare tire, and attach that piece to the tire's lug nuts or what ever is holding it up there. Then it will come down with the tire when you need it.
Matt|ttaM
