Thread: Insight 4x4
Old 12-07-2010, 04:49 AM   #18 (permalink)
Staska
Originally Posted by Hugh-Falls View Post
Staska: Thank you for the colorful sketch. It is correct and a lot clearer than a word description.
You are right about the unsprung weight being a problem with the Poulsen setup. They probably will have to use a heavy duty truck/trailer tire to prevent blowouts. There is another problem also, and that is the one concerning the torque arm connecting the wheel-mounted-motor to the chassis. This arm must be capable of changing length because the car's suspension probably travels a different path than the arm's swing.
An Etek motor weight is about 23# bare, add some kind of torque multiplication/speed reduction (4:1 or more) and you are back up to that 35-40# range. If you move the Etek motor up the arm toward the pivot, you will lessen the unsprung weight and if you have a large pulley mounted to the wheel and small at the Etek motor you could probably get about 23:80 at most which is probably not enough. You might need some additional multiplication/reduction.
Yes, you are rigth about possible solution with eteks. I also thought oabout positioning etek even on end of trailing arm. It would make unspung weight close to nilll. For mount point - i will try to show it with my fiat, and some skech-up later.
