Old 12-07-2010, 06:59 AM   #12 (permalink)
cujet
Originally Posted by arcosine View Post
A turbocharger is used in the Atkinson cycle because it is more efficient at compression that a piston (slider-crank) is near BDC. The turbine in Smokies engine does not recover waste heat.
The Prius uses an Atkinson cycle and has no turbo. Simply a camshaft that holds the intake valve open during the first part of the compression stroke. Thereby lowering the effective compression stroke and VE.
Smokey's engine uses a heat exchanger in the intake manifold.
