Old 12-06-2010, 10:09 PM   #11 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
A turbocharger is used in the Atkinson cycle because it is more efficient at compression that a piston (slider-crank) is near BDC. The turbine in Smokies engine does not recover waste heat.
Old 12-07-2010, 06:59 AM   #12 (permalink)
The Prius uses an Atkinson cycle and has no turbo. Simply a camshaft that holds the intake valve open during the first part of the compression stroke. Thereby lowering the effective compression stroke and VE.
Smokey's engine uses a heat exchanger in the intake manifold.
Old 12-07-2010, 08:41 AM   #13 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
Yes, according to the diagram, the mixture is heated from 280 to 400 F, burns and expands at 1600F, so there is some gain 8% without, considering the losses in the turbine and compressor. You can consider the second stage as additional expansion. I suppose you could go hotter with direct injection and EGR.
"The host of modern hybrids to be found today are often partly powered by what their manufacturers call Atkinson Cycle engines .The truth is that of them are true Atkinsons, primarily because the stroke of the engine is constant across all four cycles. Trick valve timing simulates Atkinson behaviour, but only to a point. True Atkinsons have shorter intake and compression strokes than power and exhaust. Honda has devised an ingenious solution, but as yet is only offering it on their small lawnmower engines."
My first CVCC engine (1977) had an exhaust heated intake manifold it got 5 mpg better than the coolant heated intake (1978), 40 vs 35 mpg. its better to heat the intake after the throttle than before. The obvious problem is it is much hotter under full throttle than part, and so it would knock. (of course I had opened it up to make hotter)
Very interesting story about Smoky.
The Following User Says Thank You to arcosine For This Useful Post:
HHOTDI (05-31-2014)
FS: Hi Voltage Fiero EV (#6 on FE log on ecomodder.com homepage) davidbr13 For Sale 1 09-09-2010 05:44 PM
EV possibility (cheap 1985 fiero) dcb Fossil Fuel Free 3 12-20-2009 11:22 PM
Trying to remember something about aero Christ EcoModding Central 6 09-27-2009 08:03 PM
Getting good mpg from my Fiero TyGuy General Efficiency Discussion 2 02-03-2009 11:37 PM
New Guy with Pontiac Fiero GT fierofury Introductions 35 11-24-2008 10:57 PM
