Old 12-07-2010, 01:08 PM   #244 (permalink)
Wonderboy
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
Small update: To remind the interested parties, I haven't really driven the CRXFi all Fall because I was suspicious of the driver's side front bearing. I finally found time over thanksgiving break to bring it in to my honda guy and get the hub pressed out. (Pressing hubs in and out is a PITA if you don't have a shop press.) Well, turns out the outer part of the hub is probably damaged too so adding new bearings will just tide the problem over for a couple months, so I'm going to the junkyard (hopefully this week) to get a whole new (used) knuckle... I'll probably just get both sides (pass. side for spare) if I can find something decent. An indoor space to work this winter is likely, so it looks like spring will be the real coming out for this car.
