Thread: Diesels and EGR
Old 12-07-2010, 02:54 PM   #1 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Diesels and EGR
I have been reading up on EGR and mpg and it seems to help in gasoline engines. It makes the engine act like a smaller engine and reduces pumping losses. There is less vacuum working against the throttle plate so the engine is more efficient at part throttle. A diesel doesn't have a conventional throttle plate so does EGR help mpg or efficiency on a diesel??
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
