Old 12-07-2010, 05:12 PM   #7 (permalink)
FalconFour
FalconFour's Avatar
LEAF - '11 Nissan LEAF
Originally Posted by mluckham View Post
This requires a four-wire connection to an Arudino (5V power, ground, SCL, SDA) but I haven't yet figured out how these will be connected to the MPGuino.
That's easy, even the prebuilt MPGuino can do it. +5v and ground, those are easy to find. SCL and SDA are, unusually enough, usually tied to analog pins. There just so happen to be (at least) 2 unused analog pins on the MPGuino. Just tie in to those, add code accordingly.
(Maybe I'm making it sound too easy? I dunno how much you already know about it...)
The Following User Says Thank You to FalconFour For This Useful Post:
mluckham (12-07-2010)
