Hi Sawickm,
Have you tried doing engineering in imperial units?
Everything has a different coefficient - and the units! - rotary slugs anybody?
When I worked in America I used to convert everything to SI - do the calculations - then convert it back to Imperial
Are there imperial units for electrical things? - Imperial Volts!
New Zealand is not perfect - but its the closest I could find!
